Eikon Proxy
Hi, we were using Eikon Proxy under windows, it was unstable but still working till today. now we need to use Eikon Terminal, but we couldn't find any manual documentation to get the code working. running the old code that worked for the Proxy, didn't work for the terminal, even after changing the ports. is there a manual that we can use to get the API working behind the Eikon Terminal? thanks
Assuming you're using Eikon Data APIs see the Quick Start Guide on the Eikon Data APIs page on this portal. For troubleshooting guide see the following article.
https://developers.refinitiv.com/article/eikon-data-apipython-troubleshooting-refinitiv
