Is ther an API to get the details of profiles retrieved
We are requesting the list of results depending on name and last name + the country of residence. The response might contains several hits. I cannot find an API to get the details of a hit. If a user goes through the web page once they get the result they can also get the details of hits returned ( individuals, companies etc...).
e.g. if I pass Oussama Ben laden as a parameter I'll have plenty of hits back but then if I want to see the details of every hits I'd like to pass the id and get the details back...
world-checkworld-check-one
Hello @szm7
I think that you can achieve what you are looking for in couple of steps using calls from the Postman collections.
First start with getting the systemId of the case (SEQ-case-retrieve: Get the system ID of a case). Once you have it you can go to the SEQ-case-investigate-results: Get screening results and get all of the hits. From there you just need to use SEQ-case-investigate-world-check-profile: Get a World-Check profile with the encoded WorldCheck one profile Id (from Screening results, use field referenceId).
Let me know if that works for you.
@szm7,
Adding to the above response.
When you use the secondary fields, the matches / profiles which do not match the submitted values are auto resolved as False, and can be ignored from fetching further details. You can refer to the below link on how to identify the resolution status of a match.
Link: https://developers.refinitiv.com/en/api-catalog/customer-and-third-party-screening/world-check-one-api/quick-start
Section: World-Check One API Resolution status of a match
You would be more interested in fetching the profiles of having STRONG and EXACT matches rather than WEAK and MEDIUM ones.
Hope this helps.
I'll try it, Thanks very much,
