Error while running market_price_edpgw_service_discovery.py example
I'm trying to run the market_price_edpgw_service_discovery.py example from here https://github.com/Refinitiv/websocket-api/tree/master/Applications/Examples/EDP/python I pass the machine id and password on the command line as --user and --password respectively. The script successfully receives a token:
EDP-GW Authentication succeeded. RECEIVED: { "access_token":, "expires_in":"300", "refresh_token":"4ea872a3-****-c53c19a531aa", "scope":"", "token_type":"Bearer" }
Subsequently it attempts to get a set of hosts from a service discovery URL:
Sending EDP-GW service discovery request to https://api.edp.thomsonreuters.com/streaming/pricing/v1/
Which results in this error:
EDP-GW service discovery result failure: 403 Forbidden Text: {"error":{"id":"159b5daf-9260-4626-a46e-72565a35500d","code":"insufficient_scope","message":"access denied. Scopes required to access the resource [trapi. streaming.pricing.read]","status":"Forbidden"}}
Failed to retrieve endpoints from EDP Service Discovery. Exiting...
Any idea what is going on here? If I comment out the service discovery and websocket code, the authentication code successfully refreshes its token every 5 minutes as expected.
I believe I am on a kind of trial setup at the moment, while contracts are being finalised, if that makes a difference.
pythontreprdp-apiwebsocketsrrto
Hi @cilchmann
Looking at the error message details, it would appear your account does not have the correct entitlements/permissions i.e. it is missing trapi. streaming.pricing.read scope.
Is your trial account meant to include realtime streaming data access - or was it limited to other e.g. non-realtime data such as historical or news etc?
If you believe you should have realtime access, you need to ask your Refinitiv Account team to get your account amended to include the above scope.
As @Umer Nalla pointed out, your account does not seem to have permission to invoke any API call. The scope parameter in response message is blank. Please contact your account manager.
