2.4k 5 5 5
How can I determine the resolution status of a match using the World-Check One API?
world-checkworld-check-one
2.4k 5 5 5
Please use the API call - 'SEQ-case-investigate-results: Get screening results' in order to fetch the results of a case for determining the resolution status.
You can determine the resolution status of the match from the object - resolution, in the response of the API call.
Also, please refer to the below link for more details on the resolution status of resolved, unresolved and auto-resolved matches.
Link : https://developers.refinitiv.com/en/api-catalog/customer-and-third-party-screening/world-check-one-api/quick-start
Section : World-Check One API Resolution status of a match
Hope this helps.
