Delayed service available
Hi team,
Does the Elektron websocket API support only calls using the actual rics and delayed rics for delayed data, or it has a delayed service available as well?
Thank you
elektron-sdktreprdp-apiwebsocketsrrtodelayed-feed
Hi @bansalshah, Elektron Websocket API can be used with ERT in cloud (which is your use case) and also with deployed/hosted TREP architecture. In the case of connection to TREP, it can be used to retrieve data from any service, including delayed service as well.
For ERT in Cloud, only the real time service is available for consumption.
