Hi I need an api endpoint and credentials in order to connect and test the elektron websocket api using node js provided examples in github, who should i contact in order to get these?? thanks
Hi @raul.leonidas.cartelle, please use the Contact Us page at Refinitiv and contact the sales team, and someone will get in touch with you to work out the details.
Hello @raul.leonidas.cartelle
The Elektron WebSocket API is a server side API deployed in TREP/ERT in Cloud server. If you already have a local TREP (or RMDS or ADS server) in your site, please contact your Market Data team to help you on the local TREP WebSocket endpoint.
If you do not have a local TREP, please contact your Refinitiv representative as suggest by my colleague above.
