Default price for bonds - Python API
With Datastream it is possible to retrieve Default Prices for bonds - for time series. If my mind serves me right it is MPD.
Is there an equivalent code for Eiokn, specifically the Eikon API for Python?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythontime-seriesbonds
3.8k 4 4 6
Hi @blucap
Here is an example you can use to retrieve the time series of a bond using an ISIN as an input
ek.get_data('DE000DB7XHP3',['TR.BIDPRICE.date','TR.BIDPRICE'],{"Sdate":'2016-01-01', "Edate":'2016-01-31'})
Thank you - However I am looking for CDS spreads, any help appreciated as I am a newby on spreads.
Hi @blucap if you are looking for CDS spreads then I recommend you to use CDSSRCH app in Eikon to find RIC codes, then you can use an example syntax to fetch the data:
ek.get_data('DB5YEUAM=R',['TR.PARMIDSPREAD.date','TR.PARMIDSPREAD'],{"Sdate":'0D', "Edate":'-10D'})
Thanks marcin.bunkowski - that is what I am looking for!
18k 21 12 20
Hi @blucap
Can you provide Eikon Desktop screenshot on the data you would like to retrieve via Python API ?
Thanks.
See below:
To be honest, any item that acts as a proxy for CDS spreads will do.
@chavalit.jintamalit see below:
Is this screeshot from Datastream product?
