Any idea what this error means?
Got the following error after subscribe.
Seems we are getting IMAGE and not updates. Request is sent with 4 path subjects eg "IDN.ANY.000761.ZK"
Using RFAJ 7.6.0.E7 with SSL/Market Feed connection
java.lang.ArrayIndexOutOfBoundsException: 442 at com.reuters.rfa.internal.connection.md.NPartSubjectHandler.getStringBuilder(NPartSubjectHandler.java:606) at com.reuters.rfa.internal.connection.md.NPartSubjectHandler.getRicName(NPartSubjectHandler.java:131) at com.reuters.rfa.internal.session.md.SubOpenReqMsg.initialize(SubOpenReqMsg.java:156) at com.reuters.rfa.internal.session.md.SubOpenReqMsg.<init>(SubOpenReqMsg.java:49) at com.reuters.rfa.internal.session.md.MarketDataSubscriberImpl.subscribe(MarketDataSubscriberImpl.java:68) at com.ml.ets.apptk.resources.rtdata.rfa.RFASource$RFAFeed.subscribeTopic(RFASource.java:396) at com.ml.ets.apptk.resources.rtdata.rfa.RFASource$RFAFeed.start(RFASource.java:370) at com.ml.ets.apptk.resources.rtdata.impl.AbstractRTFeed.activate(AbstractRTFeed.java:473) at com.ml.ets.apptk.resources.rtdata.impl.AbstractRTSource$FeedHolder.acquire(AbstractRTSource.java:66) at com.ml.ets.apptk.resources.rtdata.impl.AbstractRTSource.acquireFeed(AbstractRTSource.java:466) at com.ml.ets.apptk.resources.rtdata.impl.AbstractRTSource.acquireFeed(AbstractRTSource.java:439) at com.ml.ets.apptk.resources.rtdata.impl.AbstractRTSource.acquireFeed(AbstractRTSource.java:432) at com.ml.ets.apptk.resources.rtdata.RTDataResource.acquireFeed(RTDataResource.java:414) at com.ml.ets.apptk.resources.rtdata.taq.TAQResource.acquireFeed(TAQResource.java:587) at com.ml.ets.ice.md.RTFeedDataProvider.getFeed(RTFeedDataProvider.java:62) at com.ml.ets.ice.md.RTFeedDataProvider.init(RTFeedDataProvider.java:44) at com.ml.ets.ice.md.SFEMarketRTDataAllocator.init(SFEMarketRTDataAllocator.java:33) at com.ml.ets.ice.md.MarketDataProviderFactory.createMarketDataProvider(MarketDataProviderFactory.java:29) at com.ml.ets.ice.MLXNOrderAgent.getOrCreateOrderBook(MLXNOrderAgent.java:709) at com.ml.ets.ice.MLXNOrderAgent.addOrder(MLXNOrderAgent.java:1798)
treprfarfa-api
9.5k 10 5 7
The error occurs when an application uses many threads subscribe Market Data 4-part subject names. However, this bug has been fixed since 6.5.0.L1 as shown below:
rfaj1529; MD: Array index ex with thread id 100 and subject sub
An ArrayIndexOutOfBoundsException will occur at a boundary condition
(subscribing thread with ID 100) using Market Data 4-part subject names.
This has been corrected.
SR: 1-4650845965
The development team also confirmed that there is no any RFA 7.6.0.E7 source code which can throw ArrayIndexOutOfBoundsException.
RFA should be upgraded to the latest version,7.6.1.E2, which supports SSL connection and includes this bug fix as well in order to solve the problem. I also tested RFA version 7.6.0.E7 and 7.6.1.E2 and I have never found this error.
11.5k 16 7 10
Hello @Kung.S
I have tried to replicate the issue with RFA Java 7.6.0 E7 MDSubDemo.java. The example can subscribe 4 parts subject ("ELEKTRON_DD.ANY.000761.ZK") successfully.
mdsubdemo_app.txt
Please submit a ticket via a Contact Premium Support page with the following information:
  • How many items that the application subscribe?
  • A list of the 4 paths subjects that encounters the problem
  • Can you replicate the issue with the MDSubDemo.java?
  • The RFA trace file when the problem occurs
mdsubdemo-app.txt (6.1 KiB)
Thank you for your reply. We found out from our side that the app is still using the old version of API, unintentionally.
