Best_bid1, best_bid3 behave ?
We see daily at around 9:30am SGT, the Thai stock has replicated best_bid1, best_bid3 values, then clear to 0. Is that normal behavior ?
WHA.BKd. it duplicate BEST_BID1 with BEST_BID3 at +4.62 and BEST_BID1 clear to 0 at 10:30:02.319344.
[Mon Sep 17 8:30:02.246598] SSL_ET_ITEM_UPDATE Chan: 0 ServiceName: RSF ItemName: WHA.BKd DataFormat: 2 DataDescriptor: 0 DataLength: 114 SequenceNum: 0 ClientItemTag: 0
intelligent-tagging-apipermid-apiopen-permid-api
18k 21 12 20
Hi @vdkhanh1102
What API you are using to get the streaming data ?
Before market open, there is a closing run process which will clear out the fields.
I believe that you are seeing this closing run process.
