Is it possible to retrieve "Vessel Characteristics | Management" data using Eikon Data API? See screen attached using RIC C}CC7309530926 as an example.
If not possible to use Eikon Data API then do we have another API with this content?
Hi @Andreas.Neidhart
I got a confirmation from Vessel Team that TR.AssetBeneficialOwner will be populated with the data after 18th Oct 2019.
I have done some research and conclude that Beneficial Owner is on CDB function and it is not available via Eikon Data APIs.
thanks for confirming - would you be able to share if this data is available through any other API?
thanks
