Hi, we are using JAVA RFA SDK. Recently, we found we getting warning log as follow: "com.reuters.rfa.connection.rssl.webullSpace.ommViewAppCon Received MARKET_PRICE, MsgType.UPDATE_RESP for item Not Available on a closed stream. The item may have been closed OR the Provider may have rejected the Batch Request"
We did constantly called register() and unregisterClient(), so this frequent register and unregister action might cause this warning message.
The scenario for us, in this case, is that we only interested in getting the snapshot data instead of the streaming data. So as long as we get the response message, we will unregister the RIC.
After reviewing the develop document, we found setting indictionFlags to OMMMsg.Indication.NONSTREAMING might be the registered behavior which we need(Section 6.3.3 in DEVELOPERS GUIDE JAVA EDITION).
So our question for this non-streaming request are:
1.Does the stream close immediately after the snapshot message received?
2.Will stream closed by NONSTREAMING indication registering immediately release the Aggregate Item Limit for current Reuters User Account?
