Don't getting Realtime Feed using ThomsonReuters.Desktop.SDK.DataAccess.Signed v1.8.4
Language: C#
.Net Framework version: 4.5
I don't received callback method call. Code attached.
Kindly help me
eikon-program.txt
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonrefinitiv-realtime
eikon-program.txt (2.6 KiB)
9.7k 49 38 60
Hi @ziaul,
This sample tutorial should provide you with a complete working example.
Looking at your example vs the sample tutorial, you are not utilizing the Windows message pump while executing asynchronous calls. That is, try this:
