top level group api 401 Unauthorized on all API Calls (SEQ-1a: Get my top-level groups)
function generateAuthHeader(dataToSign){
var hash = CryptoJS.HmacSHA256(dataToSign,environment["api-secret"]);
pm.globals.set("variable_key", "variable_value");
return hash.toString(CryptoJS.enc.Base64);
} var date = new Date().toGMTString(); var dataToSign = "(request-target): get " + environment["gateway-url"] + "groups\n" +
"host: " + environment["gateway-host"] + "\n" +
"date: " + date;
var hmac = generateAuthHeader(dataToSign);
var authorisation = "Signature keyId=\"" + environment["api-key"] + "\",algorithm=\"hmac-sha256\",headers=\"(request-target) host date\",signature=\"" + hmac + "\""; postman.setEnvironmentVariable("authorisation",authorisation);
postman.setEnvironmentVariable("currentDate",date);
world-checkworld-check-onejson
Hello @Mostafa
Couple of things needs to be checked.
1. Please make sure you have put the right URL, API key and API Secret key in the Postman environment
2. The date is included in the Authorization Signature. Assuming you did not change anything with the request, please sync your clock
3. If you are using Chrome extension please make sure that you have Interceptor turned on
Hi @Mostafa can you confirm that this question is about the Connected Risk API? Thanks.
