Configuration Download Error in EIKON
Error description: Configuration Download Error
The application failed to download the product configuration.
Possible causes: • you are not connected to the network
  • the Thomson Reuters Platform is encountering problems
  • the desktop configuration is incorrect Please restore the network connection or contact your system administrator
  • --------------------------------- Technical Information: 'CBootstrapImpl::LoadProviders' ---------------------------------
    Check everything and all is set.
    I am out of the office in order to open a ticket with support.
    Any help is appreciated.
    @eunjib since I noticed is the same issue you faced sometime ago ,could you please tell me how you solved this ?
    thanks!
eikoneikon-com-apierrorconfigurationerror-handling
4.1k 4 6 11
Of course best way is to contact with refinitiv help desk or open a ticket.
If you want to fix it by yourself I will start with check your whitelist/firewall,reset network connection or reinstall app.
