RSearch : Loan extraction
I'm trying to extract loans based on criteria with the RSearch lib.
To identify the search paramaters I used the Excel Reuters addin but it seems that I can't select the Loan Universe.
Is it possible then to extract loans with API ?
Thank you !
eikoneikon-com-api
Any idea for that topic ?
If you don't see the universe for loans in the Search wizard in Excel, then you cannot search for loans using RSearch function in Excel or RSearch COM library.
It appears that at the moment loan search capability is only available in Eikon Application GUI.
Thanks for answer !
Do you know then if Refinitiv plan to develop loan search capability for RSearch ?
Since the capability to search for loans is already available in Eikon Application GUI, I'm sure at some point it will be exposed through an API as well. But I'm afraid I don't have any info on the timeframe for this, except that it's not imminent.
