Hi team,
In the documentation regarding the ERT Cloud (https://developers.refinitiv.com/elektron/websocket-api/docs?content=45485&type=documentation_item) in the section 2.8.4 about Multiple Connections, it says 5 simultaneous connections using the same access token are supported, But when I tried with more than 5 connections using the same access token, all connections were working and getting the streaming data. Can you clarify this and shed some more light into the topic?
Thank You
