Connection Samples are throwing 502 Bad Gateway error (CSharp and Python)
I just setup my refinitiv and machine accounts via the welcome emails today. I'm trying to run the sample mentioned in the welcome emails (market_price_edpgw_service_discovery.py) and I'm getting the following:
C:\temp\Examples\EDP\python>python market_price_edpgw_service_discovery.py --user <snip> --password <snip>
Sending authentication request with password to https://api.edp.thomsonreuters.com:443/auth/oauth2/beta1/token ... EDP-GW authentication result failure: 502 Bad Gateway Text: {"error":"server_error" }
I'm getting this error from multiple different machines and also when I try and run a similar C# sample.
Any suggestions? I tried putting in dummy username/password and got the same error so I don't believe this is related to my account.
treprdp-apiwebsocketsrrtosample-codeerror-502
nevermind - I was using my refinitiv username / password instead of my machine ID.
Hi @jeff.zimniewicz, I just tried the same sample and it is working, so I can assume the issue is either your credentials or network connection to EDP servers.
Are you behind a proxy server?
EDP-GW Authentication succeeded. RECEIVED:
"access_token":"eyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiIsImtpZCI6IkhQS2pEYUhiZmpLOVRfRHUxeGFJX1JaVmZfRjNDcHlEc0dTcDV5NWxCYV
EifQ.eyJkYXRhIjoie1wiY2lwaGVydGV4dFwiOlwiNGVEbnhralBxZlYyZkxIU2tXa2FZdU53ZXhoYVpFSFA1aVgyTHBVcDdnTUwtbHI1eXM5X3VvQWwtTFl....
It was a credential issue. I was using the wrong username/password. Thanks!
