Screening with exits case ID
Dears,
I have trouble when call API,
Step 1 : Screening with customer NVD_test_abc and return case id = "6eeffbab-c313-47e6-92b8-1c8e71739177"
Step 2: Rescreening customer NVD_test_abc with case id = "6eeffbab-c313-47e6-92b8-1c8e71739177" like below
-> Show error
cause:"Case IDs must be unique within the same client." and error:"CASE_ID_EXISTS"
"groupId":"{ {group-id}}",
"caseId": "6eeffbab-c313-47e6-92b8-1c8e71739177",
"entityType": "INDIVIDUAL",
"providerTypes": [
"WATCHLIST"
"name": "NVD_test_abc",
"secondaryFields":[.......
"customFields": []
Thanks!
world-checkworld-check-one
4.5k 4 7 8
@duong.nguyen,
Thank you for your query.
For rescreening a case, client will have to use the API call – “SEQ-screen-async: Screen a case” and would need the case-system-id of the saved case.
Hope this helps.
Dear Prabhjyot.Mandla,
Do you have any API using SYNC instead of ASYNC,
Note: I know how to use the API call “SEQ-screen-async: Screen a case” but we need result immediately when API call.
Thank you for your reply!
Hi Nguyen,
Thank you for your query, please see below, currently WC1 API has 4 Sync POST for your reference.
Dear Chris Lee,
Thanks for your reply, but I mean do you have any API using SYNC instead of ASYNC for re-screening using exist case id like problem above?
Thanks!
Hi Nguyen,
Thanks for your query, i am afraid re-screening can only be done asynchronously.
