Refreshing token returns error 400 (iPlanet session has been expired.)
After getting authentication token, we refresh it every 4/5 of the expire time (approx. 4 min).
From time to time (sometimes several times a day, sometimes once every few days), such refresh_token requests fail with 400 error and message "iPlanet session has been expired."
What can cause such error? How to prevent it?
elektronrefinitiv-realtimeelektron-sdkrrteta-apielektron-transport-apitoken
9.7k 49 38 60
Hi @Serge,
Are you experiencing the token expires approximately every 18 hours? This may be the reason why it is happening. I believe there is a setting within your specific account that may have set this up - I believe it is the default. In addition to what you are doing, i.e. refreshing every 4/5 of the expire time, you can also refresh apply 4/5 of the 18 hour window. I would also reach out to your Refinitiv account manager to see if this setting can be turned off.
I too get this response. I have an application that I use to test the EDP API similar to Postman but one that I wrote myself.
I run up two instances I1 and I2.
I1 GetAccessToken (grant_type=password) returns access_token and refresh_token.
I2 GetAccessToken(grant_type=password)returns access_token and refresh_token.
I1 RefreshTokens (grant_type=refresh_token) returns 'iPlanet session has been expired'
I2 RefreshTokens (grant_type=refresh_token) returns access_token and refresh_token.
I1 RefreshTokens (grant_type=refresh_token) returns 'Refresh token does not exist.'
Same client_id for both instances.
Thank you @nick.zincone.1
This may be it. We are currently evaluating Elektron in Cloud service and have trial ID that probably has that setting you mentioned.
