0 byte output file when using rmdstestclient to record data
Hi guys,
We tried to run the rmdstestclient tool to record data, but our output file is 0 bytes.
09:43:30 *user*@**machine**/rhel6_x86_64> ./rmdstestclient -S DIRECT_FEED -ef ./symbols.txt -h *host* -p 14002 -ct rssl -u exb_hk_dev -obf testrecording.dat
Number of Connection Count = 1
Creating RSSL connection Host: *host* Port: 14002
UPA server component version: ads3.2.3.L1.linux.tis.rrg 64-bit
Setting rmds connection 0x14b9540
Connection list count is 1
SupportStandby: 0
SupportBatchRequests Initial Open: Yes
SupportBatchRequests Reissue: Yes
SupportBatchClose: Yes
SupportViewRequests: Yes
SupportOptimizedPauseResume: 0
Received Field Dictionary refresh message (Data Length: 1210615).
Received Enum Dictionary refresh message (Data Length: 123585).
We have not received any error message for this, and we do have permission on the folders where we are trying to write the file.
Please let me know if I am missing something.
Thank you,
Jayson
elektronrefinitiv-realtimeelektron-sdkrmds-test-client
@jfajardo
You can use -l <file> option to log events to a file.
    -l                 Log events to the file
The command is:
./rmdstestclient -S DIRECT_FEED -ef ./symbols.txt -h host -p 14002 -ct rssl -u exb_hk_dev -obf testrecording.dat -l log.txt
Then, please share the log.txt file.
Thanks @jirapongse.phuriphanvichai! We'll rerun again and get back to you here.
Hi @jirapongse.phuriphanvichai,
Here's the log file out of a run we made for ~10 hours. capture file is again 0 bytes.
rmdstestclient-log.txt
Thank you very much!
Regards,
Jayson
@jfajardo
From the log file, DIRECT_FEED is not a correct service. The available services on the server are:
  • IDN_DEV
  • PB-NAMR-DEV
  • PB-APAC
  • PB-EMEA
  • PB-APAC-DEV
  • PB-EMEA-DEV
  • PB-NAMR
  • MBPIPE_DEV
  • MBPIPE_BETS
  • DTS_DEV
  • OBPUB_DEV
For now, please try IDN_DEV (-S IDN_DEV).
If you are still unable to retrieve the data, please contact the server team for the correct service that can provide the data.
HI @jirapongse.phuriphanvichai, thanks for this, I am now able to see the dat file with contents in it. I am looking into replaying this but my sink_driven_src is having a segfault issue. Will raise a separate quesion for this.
Thank you!
9.5k 10 5 7
Hello @jfajardo
Please make sure that:
Hope this help.
Thanks @Pimchaya.Wongrukun!
  • Yeah, double-checked that the following are correct and based on RFA.cfg:
    • -h = serverList from RFA.cfg, and
    • -S = serviceList from RFA.cfg
  1. Here is what my RicFile looks like:
6|BGRIM.BK 6|BGRIM.BKd 6|CENTEL.BK 6|CENTEL.BKd 6|BDMN.JK 6|TLKM.JK
I am unsure what below means but I thought that since these are non zero values, that my dat file should have anything in it at least:
Received Field Dictionary refresh message (Data Length: 1210615). Received Enum Dictionary refresh message (Data Length: 123585).
Thanks,
Jayson
