I'm a newbie, currently I tried to compile and run StarterConsumer example application with MSVC 2017. I already installed EZD 1.3. But then when I ran the application, I got the following error:
RFA Internal failure Application: StarterConsumer Process Id: 0xEA8 Thread Id: 0x3BA4 File: D:\Jenkins\workspace\RFACPPDEV_RCDEV\OS\VS150-32\rcdev\source\rfaut\Common\Support\Util\Impl\JIT_Support.cpp Line: 133 Problem: The specified module could not be found. RFA_VERIFY( 0 ) failed Stack Trace: 0x55B88F44 E:\Developments\Reuters\Delphi_Reuters\Wrapper\Lib\Lib\Examples\StarterConsumer\Debug_WIN_32_VS150_Shared\RFA8_SessionLayer150.dll: getGlobalEventNotifier() + 18500 bytes 0x55B8A8C6 E:\Developments\Reuters\Delphi_Reuters\Wrapper\Lib\Lib\Examples\StarterConsumer\Debug_WIN_32_VS150_Shared\RFA8_SessionLayer150.dll: getGlobalEventNotifier() + 25030 bytes 0x55B8CBE3 E:\Developments\Reuters\Delphi_Reuters\Wrapper\Lib\Lib\Examples\StarterConsumer\Debug_WIN_32_VS150_Shared\RFA8_SessionLayer150.dll: getGlobalEventNotifier() + 34019 bytes 0x55B753F1 E:\Developments\Reuters\Delphi_Reuters\Wrapper\Lib\Lib\Examples\StarterConsumer\Debug_WIN_32_VS150_Shared\RFA8_SessionLayer150.dll: rfa::sessionLayer::Session::~Session() + 8145 bytes 0x00DE886A E:\Developments\Reuters\Delphi_Reuters\Wrapper\Lib\Lib\Examples\StarterConsumer\Debug_WIN_32_VS150_Shared\StarterConsumer.exe: StarterConsumer::init() + 1530 bytes e:\developments\reuters\delphi_reuters\wrapper\lib\lib\examples\starterconsumer\starterconsumer.cpp, line 150 0x00DEBC46 E:\Developments\Reuters\Delphi_Reuters\Wrapper\Lib\Lib\Examples\StarterConsumer\Debug_WIN_32_VS150_Shared\StarterConsumer.exe: main() + 102 bytes e:\developments\reuters\delphi_reuters\wrapper\lib\lib\examples\starterconsumer\starterconsumer.cpp, line 63 0x00DF73DE E:\Developments\Reuters\Delphi_Reuters\Wrapper\Lib\Lib\Examples\StarterConsumer\Debug_WIN_32_VS150_Shared\StarterConsumer.exe: invoke_main() + 30 bytes d:\agent\_work\3\s\src\vctools\crt\vcstartup\src\startup\exe_common.inl, line 78 0x00DF72F7 E:\Developments\Reuters\Delphi_Reuters\Wrapper\Lib\Lib\Examples\StarterConsumer\Debug_WIN_32_VS150_Shared\StarterConsumer.exe: __scrt_common_main_seh() + 343 bytes d:\agent\_work\3\s\src\vctools\crt\vcstartup\src\startup\exe_common.inl, line 288 0x00DF719D E:\Developments\Reuters\Delphi_Reuters\Wrapper\Lib\Lib\Examples\StarterConsumer\Debug_WIN_32_VS150_Shared\StarterConsumer.exe: __scrt_common_main() + 13 bytes d:\agent\_work\3\s\src\vctools\crt\vcstartup\src\startup\exe_common.inl, line 331 0x00DF7448 E:\Developments\Reuters\Delphi_Reuters\Wrapper\Lib\Lib\Examples\StarterConsumer\Debug_WIN_32_VS150_Shared\StarterConsumer.exe: mainCRTStartup() + 8 bytes d:\agent\_work\3\s\src\vctools\crt\vcstartup\src\startup\exe_main.cpp, line 17 0x74946359 C:\WINDOWS\System32\KERNEL32.DLL: BaseThreadInitThunk() + 25 bytes 0x76FC7A94 C:\WINDOWS\SYSTEM32\ntdll.dll: RtlGetAppContainerNamedObjectPath() + 228 bytes 0x76FC7A64 C:\WINDOWS\SYSTEM32\ntdll.dll: RtlGetAppContainerNamedObjectPath() + 180 bytes
Is there someone that can help me with this error?
Thanks.
