API function to get total matches details
any api function can direct get the total matches details as attachement ?
world-checkworld-check-one
4.5k 4 7 8
@tsongguang.lee
If you need to know the resolution status of the matches, then you can use the API call - 'SEQ-case-investigate-results: Get screening results' as mentioned above.
If you are looking for any specific information, please let us know the exact information which you are looking for so that we may assist you with the same.
4.5k 4 7 8
@tsongguang.lee,
Apologies for the delay in response.
As of now there is no API call to form the response details in an attachment / doc format. However, you can create your own document / PDF from the data of the API call, which matches your criteria.
Hope this helps.
@Prabhjyot.Mandla
noted that current no API call to direct get the total matches details.
You suggested create own document/PDF from the data of the API call, which API call method u refer to ?
For now i using SEQ-case-investigate-results: Get screening results and loop every resolution status id to determine the screen results. Is this only or best ways to get the data as show on attachement (total screen type and matches details).
