Thomson Reuters Contributions Channel - RICs that users are contributing to
We have TRCC setup in parallel to MLIP. In MLIP, we can see what RICs our internal users are contributing to but on TRCC we havent been able so far, we have increased the logging level to debug on the rmds.cnf but that only seems to work with IDN
How can we get this working as this is a requirement for us
elektronrefinitiv-realtimetrepinfrastructurercc-apicontributions
I am good. For anyones befenefit:
adsmon -set IPCServer `hostname`.1.ads.sink.server.ipc.transmissionBus dumpIncoming True
[server]> adsmon -set IPCServer `hostname`.1.ads.sink.server.ipc.transmissionBus dumpIncoming True
server.1.ads.sink.server.ipc.transmissionBus.dumpIncoming was successfully set to True
TEXT FILTERED
server:/logs]> dbgLogMon -dumpSSLData -noUsecTS -dict RDMFieldDictionary ads.dbg0 | egrep "257|fieldEntry"
<key flags="0x7 (RSSL_MKF_HAS_SERVICE_ID|RSSL_MKF_HAS_NAME|RSSL_MKF_HAS_NAME_TYPE)" serviceId="257" name="RICTEST" nameType="1"/>
<fieldEntry fieldId="320" dataType="RSSL_DT_RMTES_STRING" data="Testing again"/>
<key flags="0x7 (RSSL_MKF_HAS_SERVICE_ID|RSSL_MKF_HAS_NAME|RSSL_MKF_HAS_NAME_TYPE)" serviceId="257" name="RBCTEST" nameType="1"/>
<fieldEntry fieldId="322" dataType="RSSL_DT_RMTES_STRING" data="Cause it needs to work"/>
VALUES FILTERED
[server:logs]> dbgLogMon -dumpSSLData -noUsecTS -dict RDMFieldDictionary ads.dbg0 | egrep "257|fieldEntry"
<key flags="0x3 (RSSL_MKF_HAS_SERVICE_ID|RSSL_MKF_HAS_NAME)" serviceId="257" name="TEST12=RIC"/>
<fieldEntry fieldId="393" dataType="RSSL_DT_REAL" data="2.2"/>
<fieldEntry fieldId="275" dataType="RSSL_DT_REAL" data="2.3"/>
<fieldEntry fieldId="393" dataType="RSSL_DT_REAL" data="2.3"/>
<fieldEntry fieldId="275" dataType="RSSL_DT_REAL" data="2.4"/>
@ivan.amo, thank you for sharing
9.5k 10 5 7
Hello @ivan.amo
If you use EMA application to contribute data to TRCC, please try to set XmlTraceToStdout to be 1 of Consumer node in EMAConfig.xml which your application uses. Then, you should see the contributed data messages including the RIC names sent to TRCC.
The example configuration to enable EMA traces its received and sent messages in XML format to stdout/console.
<Consumer>
  <Name value="Consumer_1"/>
  <Channel value="Channel_1"/>
 <XmlTraceToStdout value="1"/>
</Consumer>
Pimchaya
We dont contribute; i look after the TREP infrastructure where the TRCC is setup. So i wont be contributing using TRCC, but our customers do.
We need to be able to see what our users are contributing to, same as we could do with MLIP, just by looking at the logs on debug mode
Hello @ivan.amo
If the data is contributed to TRCC, that data go to Elektron directly. You need to consume it back from Elektron (with the same RIC name).
Please note that you cannot consume it via TRCC service directly.
11.5k 16 7 10
Hello @ivan.amo
I assume that you contribute data to TRCC/MLIP via TREP. There are some different between the TRCC and MLIP Post messages. The OMM Post message for TRCC must contains the following information
  • ACK indication flag (solicitAck(true))
  • Post ID
  • The message payload must be an Update Message type
  • Both Post message and Payload must contain the posted item name
Example code are following (in Java)
UpdateMsg nestedUpdateMsg = EmaFactory.createUpdateMsg()
	.streamId(_postStreamID)
	.name("Contribution_RIC")
	.payload(nestedFieldList);
PostMsg postMsg = EmaFactory.createPostMsg()
	.postId(_postID++)
	.serviceId(257)
	.solicitAck(true)
	.payload(nestedUpdateMsg)
	.complete(true);
Please note that you require TRCC access credential setup in you TREP and TRCC supports the Off-Stream Post only.
If you still encounter the problem, please enable the trace file and share it in this post.
9.5k 10 5 7
Hello @ivan.amo
According to Wasin's answer, you may contact your TREP Infrastructure if there is a service providing data from Elektron. Otherwise, you may have to contact Refinitiv account team who can assist you to access Elektron service.
Ok, let me try to explain differently.
Say for example IDN data, 200 users connect to our ADSs, and if i want to see what RICs they are consuming, i goto adsmon and dump the database.
Which will provide me with SERVICE, USERID and RIC, all of this in a massive list.
Now, with MLIP, i change the MLIP config to debug, and i am able to see the RICs that my clients are contributing to via the DCS Service.
With TRCC, i cannot do any of the 2 above; so i need to be able to pull out anything that my customers are contributing to.
My setup TRCC via TREP, so i have TRCC setup on a pair of ADHs that connect directly to the CHPs.
I am not the contributor, I am the support engineer in charge of looking after the TREP infrastructure and any of the components.
11.5k 16 7 10
Hi @ivan.amo
Thank you for clarification. Based on my understanding, TRCC is designed to let client contributes data to Elektron via a secure channel. It does not allow other users to check or capture that data in a middle.
I strongly suggest you contact TREP support team to help you check if TREP has any features that support your requirement or not.
Hi @ivan.amo
I have reached and the TREP team have advised that at this point in time enabling insertTrace, or dumpIncoming or dumpOutgoing, and going through the output from dbgLogMon is going to be the only option from the TREP side of things.
If you are not familiar with the above, please contact TREP support on the via the Helpdesk.
If you do have some suggestions on future functionality you can ask your Refinitiv account manager to raise them with the Product Manager.
i enabled insertTrace and indeed, it does generate a log with extension .dbg
The formatting is a bit funky to read on vi, any idea on how to read it:
PII Success TRCC TEST12=RBCL 964 1 0 0 0 Count 0^H^X]Inæ^@^@^@^@^@5^@^MáCÿ÷^@ PII Drop Client TRCC TEST12=RBCL 964 1 0 1 0 Count 0^H^X]Inæ^@^@^@^@^@2^@^Má¹Cÿ÷^@ PII Released TRCC TEST12=RBCL 964 1 1 1 0 Count 0^H^X]Inç^@^@^@^@^@5^@^C<87>°Cÿ÷^@ PII Initialized TRCC TEST12=RBCL 967 0 0 0 0 Count 0^H^X]Inç^@^@^@^@^@4^@^C<87>¶Cÿ÷^@ PII Add Insert TRCC TEST12=RBCL 967 0 0 0 0 Count 0^H^X]Inç^@^@^@^@^@5^@^E|+Cÿ÷^@ PII Drop Insert TRCC TEST12=RBCL 967 1 0 0 0 Count 1^H^X]Inç^@^@^@^@^@1^@^E|/Cÿ÷^@ PII Success TRCC TEST12=RBCL 967 1 0 0 0 Count 0^H^X]Inç^@^@^@^@^@5^@^E|1Cÿ÷^@ PII Drop Client TRCC TEST12=RBCL 967 1 0 1 0 Count 0^H^X]Inç^@^@^@^@^@2^@^E|3Cÿ÷^@ PII Released TRCC TEST12=RBCL 967 1 1 1 0 Count 0^H^X]Inç^@^@^@^@^@5^@ +ËCÿ÷^@ PII Initialized TRCC TEST12=RBCL 970 0 0 0 0 Count 0^H^X]Inç^@^@^@^@^@4^@
"ads.dbg1" [noeol][converted] 12L, 17451C
ignore, dbglogmon does that
the last question, can insertTrace be permanently set to true on the rmds.cnf or can only be done on the fly via adsmon
Hi @ivan.amo
Looking at the documentation the insertTrace appears to be an interactive parameter - there is nothing about adding it to the config file. Probably because of the negative impact it can have on performance - if left on all the time.
However, I would recommend you confirm with the TREP helpdesk if the above is the case.
Tks guys, i will play around and see where i get
