Returned values using PermID is different from using orgID
Hi all,
I wanted to retrieve the employees of the company Claire's INC, when I type employees in the Data Item Browser it advises me to use the field 'TR.PCFullTimeEmployees'. But for my surprise if I use python to get the data and using the orgid as instrument I do not get anything. On the other hand, if I use permid I get the data.
Why is this happening? Is there any way to get the permid knowing the orgid?
Thanks in advance!!!
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythondata-item-browser
18k 21 12 20
Hi @miriam.benito
I think you can use this field.
I found that TR.OrganizationID works. But do you know why using the permID I get the value while using the orgid I don't?
Hi @miriam.benito
I do not know the reason from the content side.
However, if you try to use "108659535" with Item Data Browser, it also does not recognize this ORG ID.
@miriam.benito
PermID is the preferred identification scheme. OrgID is a legacy scheme, which you should shun in favor of PermID. OrgID is provided for backwards compatibility, but it's not being enhanced especially for private companies.
