Repeated Timeouts
Is there a way to modify the timeout parameter in the eikon api ? I am getting a lot of Request Timeouts and it usually works when I restart the program. Internet connectivity and speed is not the issue here. Can someone please guide me in case there is a way to increase the timeout for connection on Eikon API or should I be looking at something else ?
eikon.eikonError.EikonError: Error code 408 | Request timeout occured
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonconnection
Actually I decided to modify the API and then discovered that there is a configureable timeout. I am using it and seems to be working as expected.
Great. Thanks for the update.
9.7k 49 38 60
Hi @abbanerjee,
There is no timeout parameter you can modify unfortunately. I would suggest instead reduce the amount of data in your request by limiting the timeframe (date range for example). See this thread for related question.
How about using set_timeout in the API ?
Hi @abbanerjee,
Thank you for pointing this out. I have not tried this but according to the documentation it should do what you may need. Did you try it?
