Field for currency in timeseries
Hi, I'm using Eikon to pull data into Python. This is the line I use to pull data:
ek.get_timeseries(sym,start_date='2016-03-03',end_date= sheet['B4'].value, interval = 'daily')['CLOSE']
where 'sym' is a variable for RIC that keeps changing. The RICs I'm using all have different currencies. I was wondering if there was a way to define the currency in which I want the data to be pulled within the timeseries function or if there was any other way to do this. Thanks!
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythontime-series
Hi @mchoudhary0,
I don't understand what you are trying to do. The mechanism to fetch the daily timeseries value for the different currencies is correct. Can you elaborate?
get_timeseries method can only return price history in the currency in which the instrument is traded. If your instruments are stocks or indices you can use get_data method with TR.PriceClose field, which can return price history in the currency of your choice:
ek.get_data('AAPL.O',['TR.PriceClose.date;TR.PriceClose'],
           {'SDate':'2019-05-01', 'EDate':'2019-07-01', 'CURN':'JPY'})
What if I want monthly data instead of daily data using ek.get_data? What should I do with the above command? Thanks a lot.
