Directed here by a Senior Technical Specialist from Refinitiv ticket: 7790900
Having discussed this with our Mutual Client we wanted to get some more insight into the issue reported in 7790900.
Because the connection to the EED didn't appear to have failed we didn’t failover which meant that we didn't get any Market Data due to an issue with the EED. We had to manually configure this to point to another EED in order to get that application to work as expected with an overnight change.
From what was stated by the Technical Specialist, it is our impression that there is no way to manually failover to another EED in a serverList without having the restart our application with a edited configuration as this would “shut down connectivity to the affected EDGE”, is there no other functionality via an API to do this failover Manually without having to stop our application?
