The rates i see on Eikon differs from the rates i get using excel API
Hi @tan.jieyong
Most probably you are using fields that hold last close value. With the syntax below you can see that the timestamp is not the current date.
ek.get_data('SGDSB6SO1Y=PREA',['TR.BIDPRICE.date','TR.BIDPRICE','TR.ASKPRICE'])
If you want to get real time values that are visible on the quote, you need to use real time fields. You can get them by hovering over the value on the quote.
The syntax would be
ek.get_data('SGDSB6SO1Y=PREA',['PRIMACT_1','SEC_ACT_1'])
Hi @tan.jieyong
For authoritative answer on content question, please contact Refinitiv content helpdesk at this URL.
