Are the endpoints under /data/news/beta1/ closed these days? None of the send button seems to work now.
Hi @hsss,
If the Send button is disabled, that typically means there could be permission issue. I'm assuming you are referring to the API Playgound. If this is the case, you may need to reach out to your Refinitiv account manager to confirm you have valid access to these endpoints.
I just tried and the send button is active for me.
Still working. How are you using the endpoint - in code or through Swagger documentation. Which exact endpoint isn't working for you?
