Can you please advise how we can turn on logging in ETA (I am working from the basicConsumer.java tutorials)
Ideally I want to generate output similar to below (which was shown to me by a Refinitiv Technical specialist):
1) Service: ELEKTRON_DD ConnectionType: rssl ServerHostname: localhost SipcVersion: 4 Number of Connection Count = 1 Creating RSSL connection Host: localhost Port: 14002 UPA server component version: ads_edge2.5.6.win 64-bit (ssl7.1.F30) Setting rmds connection 0000000001EAF720 Connection list count is 1 [Tue Jul 23 14:15:17.632] Received login response. SupportStandby: 0 SupportBatchRequests Initial Open: No SupportBatchRequests Reissue: No SupportBatchClose: No SupportViewRequests: No SupportOptimizedPauseResume: 0 [Tue Jul 23 14:15:17.633] Received source directory response. [Tue Jul 23 14:15:17.660] Received source directory update. [Tue Jul 23 14:15:17.660] ELEKTRON_DD Group 1 OK Received. Text "New Session Mounted" [Tue Jul 23 14:15:17.660] Received source directory update. [Tue Jul 23 14:15:17.660] ELEKTRON_DD Group 3 OK Received. Text "New Session Mounted" [Tue Jul 23 14:15:17.660] Received source directory update. [Tue Jul 23 14:15:17.660] ELEKTRON_DD Group 6 OK Received. Text "New Session Mounted" [Tue Jul 23 14:15:17.660] Received source directory update. [Tue Jul 23 14:15:17.660] ELEKTRON_DD Group 4 OK Received. Text "New Session Mounted" [Tue Jul 23 14:15:17.660] Received source directory update. [Tue Jul 23 14:15:17.660] ELEKTRON_AD Group 1 OK Received. Text "New Session Mounted" [Tue Jul 23 14:15:17.660] Received source directory update. [Tue Jul 23 14:15:17.660] ELEKTRON_AD Group 3 OK Received. Text "New Session Mounted" [Tue Jul 23 14:15:17.660] Received source directory update. [Tue Jul 23 14:15:17.660] ELEKTRON_AD Group 6 OK Received. Text "New Session Mounted" [Tue Jul 23 14:15:17.660] Received source directory update. [Tue Jul 23 14:15:17.660] ELEKTRON_AD Group 4 OK Received. Text "New Session Mounted" [Tue Jul 23 14:15:17.716] sendOpenRequest(): Writing open of size 27. [Tue Jul 23 14:15:17.716] Channel: 1 Opening item MRN_STORY of domain 33 in Service: ELEKTRON_DD [Tue Jul 23 14:15:17.716] <refreshMsg domainType="RSSL_DMT_NEWS_TEXT_ANALYTICS" streamId="5" containerType="RSSL_DT_FIELD_LIST" flags="0x1FA (RSSL_RFMF_HAS_PERM_DATA|RSSL_RFMF_HAS_MSG_KEY|RSSL_RFMF_HAS_SEQ_NUM|RSSL_RFMF_SOLICITED|RSSL_RFMF_REFRESH_COMPLETE|RSSL_RFMF_HAS_QOS|RSSL_RFMF_CLEAR_CACHE)" groupId="1" seqNum="26832" permData="0301 0110 001C" qosDynamic="0" qosRate="1" qosTimeliness="1" dataState="RSSL_DATA_OK" streamState="RSSL_STREAM_OPEN" code="RSSL_SC_NONE" text="All is well" dataSize="102"> <key flags="0x7 (RSSL_MKF_HAS_SERVICE_ID|RSSL_MKF_HAS_NAME|RSSL_MKF_HAS_NAME_TYPE)" serviceId="257" name="MRN_STORY" nameType="1"/> </refreshMsg> PROD_PERM : UINT 2 : [10001] ACTIV_DATE : DATE 4 : [20 JUL 2019] RECORDTYPE : UINT 1 : [30] RDN_EXCHD2 : ENUM 2 : [1370] TIMACT_MS : UINT 4 : [37547505] GUID : STRING 0 : [] CONTEXT_ID : REAL 3 : [3752] DDS_DSO_ID : UINT 2 : [8328] SPS_SP_RIC : STRING 10 : [.[SPSML0L1] MRN_V_MAJ : STRING 1 : [2] MRN_TYPE : STRING 5 : [STORY] MRN_V_MIN : STRING 2 : [10] MRN_SRC : STRING 9 : [HDC_PRD_A] FRAG_NUM : UINT 1 : [1] TOT_SIZE : UINT 1 : [0] FRAGMENT : STRING 0 : [] Image Received. RespFlags<0x140> FragCount<0> PendQ Count<0000> PendOutQ Count<0001> GroupId<1>:<MRN_STORY>:<33> [Tue Jul 23 14:16:09.422] <updateMsg domainType="RSSL_DMT_NEWS_TEXT_ANALYTICS" streamId="5" containerType="RSSL_DT_FIELD_LIST" flags="0x1DA (RSSL_UPMF_HAS_PERM_DATA|RSSL_UPMF_HAS_MSG_KEY|RSSL_UPMF_HAS_SEQ_NUM|RSSL_UPMF_DO_NOT_CACHE|RSSL_UPMF_DO_NOT_CONFLATE|RSSL_UPMF_DO_NOT_RIPPLE)" updateType="0 (RDM_UPD_EVENT_TYPE_UNSPECIFIED)" seqNum="27582" permData="0301 0110 121B 1025 5B10 263B 1026 7B10 279B 1028 1B10 288B 1030 3B10 310B 1200 0B12 002B 1203 8B12 059B 1219 9B12 212B 1228 9B12 292B 1229 6B12 320B 1232 3C" dataSize="2717"> <key flags="0x7 (RSSL_MKF_HAS_SERVICE_ID|RSSL_MKF_HAS_NAME|RSSL_MKF_HAS_NAME_TYPE)" serviceId="257" name="MRN_STORY" nameType="1"/> </updateMsg>
