eikon data api passing parameter
ric=['7207.T']
fields = ['TR.GICSSector', 'TR.GICSIndustry', 'TR.ClosePrice', 'CF_CURR', 'TR.CompanyMarketCap']
params={'TR.CompanyMarketCap': {'CURN':'USD'}}
ndata = eikon_data.get_data( rics, fields,params);
Could you help me with passing arguments to get_data function? For example, I'd like marketcap in USD and above code does not work.
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonparameters
  • 7207.T is not a valid RIC.
  • To apply CURN parameter only to TR.CompanyMarketCap use
ek.get_data('7201.T',['TR.GICSSector', 'TR.GICSIndustry', 'TR.ClosePrice',
                      'CF_CURR', 'TR.CompanyMarketCap(CURN=USD)'])
To apply CURN parameter only to all fields which accept this parameter (in this case it will be TR.ClosePrice and TR.CompanyMarketCap) use
                      'CF_CURR', 'TR.CompanyMarketCap'],{'CURN':'USD'})
  • Check out this tutorial, which talks at length about finding metadata (field names and parameters) for use with Eikon Data APIs.
thank you!
