Eikon Data API field name for yield at issue
Does there exist a field which contains the yield at issue for a bond in the Eikon Data API? I have not been able to locate this field using the data browser on the proxy.
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonbondsyield
23k 22 9 14
Hello @javan.graham and all,
Content advised to use "TR.FiOriginalYieldMaturity"
18k 21 12 20
Hi @javan.graham
This forum is moderated by developer who are familiar with API calls and sample code.
For content question, please contact Refinitiv Data Helpdesk at this URL for authoritative answer.
Sorry. Thank you for the referral and great support.
23k 22 9 14
Hello @javan.graham,
A totally correct approach you have taken, is to search the field through DIB, by setting RIC on the bond and searching for yield-containing fields.
However, some content questions are not obvious or easy to find the answers to. In this case the best and most efficient next step is to open a content support case with Refinitiv Helpdesk, and your content question will be routed to the appropriate Refinitiv content matter expert.
I have submitted the above question on your behalf. Your case# is 07797833
You will be contacted on your developers portal registration email.
-AHS
Thank you very much.
