Requested field values from get_timeseries into different currencies.
Getting prices from get_timeseries, using RICs for companies, will get you the values in the reported currency (e.g. if its a company from .HK, will report values in HKD, am I right?).
Is there a way to request the field values in a currency different than the one that's reported?
Say, get BID and ASK for some company from .HK in USD instead of HKD?
Thanks for any help provided.
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonforex
18k 21 12 20
Hi @aquilesjlp300
According to document on get_timseries at this URL
It seems that the function does not support currency.
However, you can follow this example using get_data
