Refresh DSGRID functions in excel from VBA sub and wait for refresh to be finished before continuing with the code execution
Dear all,
We have developed a portfolio optimisation code that runs with VBA over one excel file that is in practice a support database.
The code loops through several non linear weighting scenarios to arrive to an optimum portfolio configuration.
During these processes the system does not need to refresh data from DS as an initial download is made before running the code.
But once the stock selection is finished, we need to update several DSGRID cells related to the selected stocks before continuing some further code lines.
We are currently using this instruction for the intermediate refresh:
Application.COMAddIns("PowerlinkCOMAddIn.COMAddIn").Object.RefreshActiveWorkbook
Despite it seems to be working, we do not know why or if other instructions would be better
We have used other instructions
Application.Run "PLRefreshWorkbookEventHandler"
And
Application.Run "EikonRefreshWorkbook"
The problem is that we are not sure which is the proper refresh system as we need synchronous refresh (sequential), meaning the VBA code temporarily stops execution until all refreshes are finished.
could you help us to clarify this issue?
Thank you very much in advance
Ivan
eikon-com-apidatastream-apidsws-apivba
Hi, This is regarding the the excel addin and not DSWS the API. You can raise these requests over the helpdesk. In the meantime for your reference datastream-dfo-vba-commands-vs4.pdf may help
