We are publishing a internal Yield Curve using the Yield Curve format on a ADS via TREP Post contribution, message are accepted by the ADS and we can retrieve then in consumer application. But the field of type vector, is always empty on the first load of the consumer, all other fields are cached and when we subscribe, the last data that was send is retrieved, but vector entries are always empty until we re-send the yield curve. Is necessary some configuration to cache this on the ADS or is an invalid usage of the Vector type?
