Calling the same TR_Field with better parameters?
I am calling the same TR_Field - TR.TotalReturn1Mo, with different dates as parameters but getting the same number returned.
fields = [ek.TR_Field('TR.TotalReturn1Mo',{'SDate': '2018-01-20'}), ek.TR_Field('TR.TotalReturn1Mo',{'SDate': '2018-01-10'})]
df,response = ek.get_data(list_RIC_Codes, fields)
The df response has the same number for both fields - suggesting that the first field is being queried twice.
Is there a problem calling the same TR_Field with different parameters?
18k 21 12 20
Hi @james.kennedy
I got the response successfully with different value.
You can use different parameters on the same field.
9.7k 49 38 60
Hi @james.kennedy,
Perhaps the results may be a due to the nature of the instruments and the time frames. Did you try the requests separately? Can you include a small example for us to try?
I did the following and the results came back different, i.e.
got it fixed - thanks very much for your help
