Installing eikon package for Python
I tried to install eikon package for Python on a new computer.
I ran "pip install eikon" from Windows command prompt, then this error message appeared.
"pip is configured with locations that require TLS/SSL, however the ssl module in Python is not available."
As written in https://stackoverflow.com/questions/54394764/pip-is-configured-with-locations-that-require-tls-ssl-however-the-ssl-module-i/54394791,
I added the path to libeay32.dll. However, it's not working.
This may not be a suitable question to post here. However, I appreciate if you can help me.
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonsetup
7.6k 15 6 9
@gyuwa
Are you running python and pip command behind Proxy?
Can you try below command ?
pip install https://files.pythonhosted.org/packages/16/4a/946a2000455a84bf62a25c2933500b33ff0383ab873bf56860b8732a8ff6/eikon-1.0.1-py3-none-any.whl
If it's the problem from proxy you might need to try setting proxy using the following command
pip install packageName --proxy proxy_Server:portnumber
ex: pip install numpy --proxy https://myproxy@myserver.com:8080
