python Eikon API login
We are trying to set up the calculation for a custom metric on AWS lambda which requires a data input from Eikon apart from some of the inhouse data points. Is there a way where we can automate the sign in and sign off process to Eikon thorough API using python so that the entire process can be automated on the AWS itself.
18k 21 12 20
Hi @nilam
It is not possible to automate the process using the Eikon Data APIs.
Eikon Data APIs is designed to be used on user desktop, it is a Desktop Product.
You may consider Enterprise Products for data feed solution to your AWS calculation.
