problem with getting data with python
every time i run this code:
import eikon as ek
ek.set_app_key("my_app_key")
df = ek.get_timeseries(["COMI.CA"], start_date="2016-01-01", end_date="2016-01-10") print(df.head())
i recive this error
]: runfile('D:/my drive/Python Projects/eikon/test001.py', wdir='D:/my drive/Python Projects/eikon') Error on checking port 9000 : HTTPConnectionPool(host='localhost', port=9000): Max retries exceeded with url: /api/v1/data (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x000002664A5BEB70>: Failed to establish a new connection: [WinError 10061] No connection could be made because the target machine actively refused it',)) Error on checking port 9000 : HTTPConnectionPool(host='localhost', port=9000): Max retries exceeded with url: /api/v1/data (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x000002664A5BE748>: Failed to establish a new connection: [WinError 10061] No connection could be made because the target machine actively refused it',)) Error on checking port 36036 : HTTPConnectionPool(host='localhost', port=36036): Max retries exceeded with url: /api/v1/data (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x000002664A5BE6D8>: Failed to establish a new connection: [WinError 10061] No connection could be made because the target machine actively refused it',)) Error on handshake port None : Failed to parse: localhost:None Port number was not identified. Check if Eikon Desktop or Eikon API Proxy is running. Traceback (most recent call last): File "<ipython-input-6-816572c984fb>", line 1, in <module> runfile('D:/my drive/Python Projects/eikon/test001.py', wdir='D:/my drive/Python Projects/eikon') File "C:\Users\MArmia\Anaconda3\lib\site-packages\spyder\utils\site\sitecustomize.py", line 705, in runfile execfile(filename, namespace) File "C:\Users\MArmia\Anaconda3\lib\site-packages\spyder\utils\site\sitecustomize.py", line 102, in execfile exec(compile(f.read(), filename, 'exec'), namespace) File "D:/my drive/Python Projects/eikon/test001.py", line 3, in <module> ek.set_app_key("af6ed7495e654418af715318c4d90a9afd864f31") File "C:\Users\MArmia\Anaconda3\lib\site-packages\eikon\Profile.py", line 48, in set_app_key get_profile().set_app_key(app_key) File "C:\Users\MArmia\Anaconda3\lib\site-packages\eikon\Profile.py", line 207, in set_app_key self.check_profile() File "C:\Users\MArmia\Anaconda3\lib\site-packages\eikon\Profile.py", line 322, in check_profile raise EikonError(-1, 'Port number was not identified. Check if Eikon Desktop or Eikon API Proxy is running.') NameError: name 'EikonError' is not defined
@michael.armia
It appears that you're not a Refinitiv customer. You're a customer of the company named Metastock using their product named Metastock Xenith, which includes a low tier variant of Eikon. Metastock Xenith users are not entitled to Eikon Data APIs. If you'd like to use Eikon Data APIs, you need to subscribe to a higher tier Eikon variant from Refinitiv. You cannot get access to Eikon Data APIs through Metastock.
@michael.armia
I get the same error if Eikon Desktop or Eikon API Proxy isn't running on the machine.
Please make sure that Eikon Desktop or Eikon API Proxy is running properly on the same machine. Eikon Data API needs to connect to Eikon Desktop or Eikon API Proxy running on the same machine in order to work properly.
Dear @jirapongse.phuriphanvichai than;s for your response i am already running Eikon Desktop but i still receive the same error
@michael.armia
From the trace you included it looks like Eikon API Proxy, which is embedded in Eikon Desktop application, is not running on the machine where your Python script is executed. Could you confirm that you indeed are running Eikon Desktop (and not Eikon Web) on the same machine where your Python scripts are running and that Eikon Desktop is up and signed in at the time the script is executed? Can you see if the following file exists on your machine and what the content is in this file? You can open the file with a text editor like Notepad. It should contain the single number (typically 9000), which is the port number Eikon API Proxy is listening on. The file is created on the startup of Eikon.
%APPDATA%\Thomson Reuters\Eikon API Proxy\.portInUse
@michael.armia
I have created a PowerShell script to verify the basic environment for Eikon Data API, such as Eikon Processes, listening ports, PortInUse file, and connection. Please run the script and share the output.txt file.
checkeikondataapips1.txt
Please rename it to checkeikondataapi.ps1 and run it in the PowerShell command line.
i received this error:
PS C:\Users\MArmia\Desktop> .\checkeikondataapi.ps1
.\checkeikondataapi.ps1 : File C:\Users\MArmia\Desktop\checkeikondataapi.ps1 cannot be loaded
because running scripts is disabled on this system. For more information, see
about_Execution_Policies at https:/go.microsoft.com/fwlink/?LinkID=135170.
At line:1 char:1
+ .\checkeikondataapi.ps1
+ CategoryInfo : SecurityError: (:) [], PSSecurityException
+ FullyQualifiedErrorId : UnauthorizedAccess
@michael.armia
You need to run the PowerShell command as Administrator to change the policy and then use the following command.
 Set-ExecutionPolicy -ExecutionPolicy Bypass -Scope LocalMachine
Next, you can run the script.
Finally, you may need to change it back to Undefined.
Set-ExecutionPolicy -ExecutionPolicy Undefined -Scope LocalMachine
1. List all Eikon processes
Handles NPM(K) PM(K) WS(K) CPU(s) Id SI ProcessName
1064 52 30408 60120 2.97 5808 3 Eikon
773 43 45840 55208 3.91 1872 3 EikonBox
915 44 20020 50840 1.17 3052 3 EikonBox
731 57 43932 62672 1.52 3996 3 EikonBox
503 33 31592 44808 0.89 13648 3 EikonBox
385 33 32460 51900 0.53 13844 3 EikonBox
408 68 17132 25272 0.48 17328 3 EikonBox
751 78 64524 79868 2.41 17984 3 EikonBox
460 39 50204 65080 0.95 21548 3 EikonBox
1023 78 62976 79552 1.05 2352 3 EikonBoxNet
1658 74 73036 87588 5.00 6664 3 EikonBoxNet
805 54 62336 71132 1.97 12652 3 EikonBoxNet
820 51 39848 58040 1.56 16860 3 EikonBoxNet
Process: Eikon.exe
ProcessId CommandLine
5808 "C:\Program Files (x86)\Thomson Reuters\Eikon\Y\Bin\Eikon.exe" -background
Process: EikonBox.exe
17328 "C:\Program Files (x86)\Thomson Reuters\Eikon\Y\Bin\EikonBox.exe" -pa -a --pid=5808 --pa-inactive
--pa-version=9.47.0.108 --pa-path="C:\Program Files (x86)\Thomson
Reuters\Eikon\Y\Bin\Apps\THOMSONREUTERS.EIKON.PROXY\0.0.0.0"
1872 "C:\Program Files (x86)\Thomson Reuters\Eikon\Y\Bin\EikonBox.exe" -al -a -cp
"C:\Users\MArmia\AppData\Local\Thomson Reuters\Eikon User\Cache" -p AppLibAgent -g
5E0DC8E2-B9C3-4B0A-BD24-A4FF0606678B -e 5808
3052 "C:\Program Files (x86)\Thomson Reuters\Eikon\Y\Bin\EikonBox.exe" -v3 --pid=5808
--guid=EikonViewer.Singleton.9.47.0.108 --pipeid=EikonViewer.Singleton.9.47.0.108 --starterpid=5808
--device-scale-factor=1 --lang=en-US --disable-gpu-process-prelaunch --disable-gpu-watchdog
--child-clean-exit --process-per-site --disable-spell-checking --proxy-bypass-list=http://localhost:8043
13648 "C:\Program Files (x86)\Thomson Reuters\Eikon\Y\Bin\EikonBox.exe" -v3 -v3 --type=gpu-process
--disable-gpu-watchdog --no-sandbox --log-file="C:\Program Files (x86)\Thomson
Reuters\Eikon\Y\Bin\debug.log" --log-severity=disable --user-agent="Mozilla/5.0 (Windows NT 6.1)
AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.3071.0.0 EikonViewer/59.3071.0.0 Safari/537.36" /prefetch:2
--pid=5808 --guid=EikonViewer.Singleton.9.47.0.108 --pipeid=EikonViewer.Singleton.9.47.0.108
--starterpid=5808 --disable-direct-composition --supports-dual-gpus=false
--gpu-driver-bug-workarounds=7,10,11,19,20,21,24,43,63,76
--disable-gl-extensions="GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent"
--gpu-vendor-id=0x8086 --gpu-device-id=0x5917 --gpu-driver-vendor="Intel Corporation"
--gpu-driver-version=23.20.16.4973 --gpu-driver-date=2-28-2018 --log-file="C:\Program Files (x86)\Thomson
--lang=en-US --pid=5808 --guid=EikonViewer.Singleton.9.47.0.108 --pipeid=EikonViewer.Singleton.9.47.0.108
--starterpid=5808 --child-clean-exit --service-request-channel-token=14CFD219499821B2C89295440D7E89DC
--mojo-platform-channel-handle=1980
3996 "C:\Program Files (x86)\Thomson Reuters\Eikon\Y\Bin\EikonBox.exe" -tsi -a -eikonpid=5808
-EikonProcessId=5808 -HwndComInterop=0x1 -ll=2 -perfLevel=0 -context="C:\Users\MArmia\AppData\Local\Thomson
Reuters\Eikon User\Cache\LibraryCache\Apps\THOMSONREUTERS.EIKON.TSI6\6.4.2013.44564\"
17984 "C:\Program Files (x86)\Thomson Reuters\Eikon\Y\Bin\EikonBox.exe" -pixl -context="C:\Program Files
(x86)\Thomson Reuters\Eikon\Y\Bin\Apps\THOMSONREUTERS.REALTIME.PIXLALLPROTOCOLS\0.0.0.0" -a 3996
13844 "C:\Program Files (x86)\Thomson Reuters\Eikon\Y\Bin\EikonBox.exe" -v3 --type=renderer --js-flags=--expose-gc
--no-sandbox --child-clean-exit --primordial-pipe-token=70D9C30D15078080F5A8064477476C39
--log-file="C:\Program Files (x86)\Thomson Reuters\Eikon\Y\Bin\debug.log" --log-severity=disable
--user-agent="Mozilla/5.0 (Windows NT 6.1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.3071.0.0
EikonViewer/59.3071.0.0 Safari/537.36" --disable-spell-checking /prefetch:1 --lang=en-US --pid=5808
--enable-pinch --device-scale-factor=1 --num-raster-threads=4 --enable-main-frame-before-activation --content
-image-texture-target=0,0,3553;0,1,3553;0,2,3553;0,3,3553;0,4,3553;0,5,3553;0,6,3553;0,7,3553;0,8,3553;0,9,35
53;0,10,3553;0,11,3553;0,12,3553;0,13,3553;0,14,3553;0,15,3553;0,16,3553;1,0,3553;1,1,3553;1,2,3553;1,3,3553;
1,4,3553;1,5,3553;1,6,3553;1,7,3553;1,8,3553;1,9,3553;1,10,3553;1,11,3553;1,12,3553;1,13,3553;1,14,3553;1,15,
3553;1,16,3553;2,0,3553;2,1,3553;2,2,3553;2,3,3553;2,4,3553;2,5,3553;2,6,3553;2,7,3553;2,8,3553;2,9,3553;2,10
,3553;2,11,3553;2,12,3553;2,13,3553;2,14,3553;2,15,3553;2,16,3553;3,0,3553;3,1,3553;3,2,3553;3,3,3553;3,4,355
3;3,5,3553;3,6,3553;3,7,3553;3,8,3553;3,9,3553;3,10,3553;3,11,3553;3,12,3553;3,13,3553;3,14,3553;3,15,3553;3,
16,3553;4,0,3553;4,1,3553;4,2,3553;4,3,3553;4,4,3553;4,5,3553;4,6,3553;4,7,3553;4,8,3553;4,9,3553;4,10,3553;4
,11,3553;4,12,3553;4,13,3553;4,14,3553;4,15,3553;4,16,3553
--service-request-channel-token=70D9C30D15078080F5A8064477476C39 --renderer-client-id=3
--mojo-platform-channel-handle=2436
21548 "C:\Program Files (x86)\Thomson Reuters\Eikon\Y\Bin\EikonBox.exe" -v3 --type=renderer --js-flags=--expose-gc
--no-sandbox --child-clean-exit --primordial-pipe-token=604202AEFEAF6B12A047718B28A8EEA6
--service-request-channel-token=604202AEFEAF6B12A047718B28A8EEA6 --renderer-client-id=4
--mojo-platform-channel-handle=2584
Process: EikonBoxNet.exe
16860 "C:\Program Files (x86)\Thomson Reuters\Eikon\Y\Bin\EikonBoxNet.exe" -b -a -EikonPipe true -EikonPipeId 5808
-EikonProcessId 5808 -HwndComInterop 0x1 -AffinityName
singleInstance[THOMSONREUTERS.EIKON.STARTERNET]_08A9D1C8 -Context "C:\Program Files (x86)\Thomson
Reuters\Eikon\Y\Bin\Apps\THOMSONREUTERS.EIKON.STARTERNET\0.0.0.0" -DelayInitKobraProvider true /prefetch:4
6664 "C:\Program Files (x86)\Thomson Reuters\Eikon\Y\Bin\EikonBoxNet.exe" -b -a -EikonPipe true -EikonPipeId 5808
singleInstance[TR.FLOATINGTOOLBAR.MANAGEDCONTAINERSERVICE]_42931033 -Context
User\Cache\LibraryCache\Apps\THOMSONREUTERS.EIKON.FLOATINGTOOLBAR\4.84.0.2"
"-manifest=C:\Users\MArmia\AppData\Local\Thomson Reuters\Eikon
User\Cache\LibraryCache\9.0.47109_R12-959837__EikonContainer.dll.manifest
12652 "C:\Program Files (x86)\Thomson Reuters\Eikon\Y\Bin\EikonBoxNet.exe" -b -a -EikonPipe true -EikonPipeId 5808
-EikonProcessId 6664 -HwndComInterop 0x1 -AffinityName
singleInstance[THOMSONREUTERS.EIKON.OPSCONSOLE]_62724554 -Context "C:\Users\MArmia\AppData\Local\Thomson
Reuters\Eikon User\Cache\LibraryCache\Apps\THOMSONREUTERS.EIKON.OPSCONSOLE\4.0.17.5"
2352 "C:\Program Files (x86)\Thomson Reuters\Eikon\Y\Bin\EikonBoxNet.exe" -b -a -EikonPipe true -EikonPipeId 5808
singleInstance[ThomsonReuters.Eikon.UdaService]_49538252 -Context "C:\Users\MArmia\AppData\Local\Thomson
Reuters\Eikon User\Cache\LibraryCache\Apps\THOMSONREUTERS.EIKON.UDASERVICE\2.10.13.3"
2. List all listening ports of Eikon processes
LocalAddress LocalPort State OwningProcess
127.0.0.1 8088 Listen 3052
127.0.0.1 8043 Listen 17328
127.0.0.1 8042 Listen 17328
127.0.0.1 8000 Listen 17984
3. Check portInUse file
C:\Users\MArmia\AppData\Roaming\Thomson Reuters\Eikon API Proxy\.portInUse is found
9000
4. Verify the connection to TCP Port: 9000
GET: http://127.0.0.1:9000/sxs/v1
Exception: Unable to connect to the remote server
GET: http://127.0.0.1:9000/ping
POST: http://127.0.0.1:9000/api/v1/data
From the output, there is no Eikon process listening on TCP port 9000. Below is my output.
The Eikon process that owns this port is Eikonbox.exe (16544).
The context for this process is THOMSONREUTERS.EIKON.DESKTOPSXSSVC.
I couldn't find this process on your output. This is why you are unable to use Eikon Data API.
You may need to restart the machine, run Eikon, and then re-run the script. If there is still no Eikon process listening on TCP port 9000, your account may not have permission to use this service.
The output from my machine and new script that prints the creation date of PortInUse file are attached.
output.txt
output.txt (33.1 KiB)
@michael.armia
Are you by any chance using Metastock Xenith product? If not, which variant of Eikon do you subscribe to? Could you also check which version of Eikon you're running? You can check the latter by selecting Help - About Thomson Reuters Eikon from the main Eikon menu.
@Alex Putkov.
My Eikon version is :
Desktop 4.0.48(4.0.48064)
This exception message says you're trying to connect to the same host ( 127.0.0.1 ), while you're stating that your server is running on a different host. This 127.0.0.1 represents a 'loopback' . It allows the computer to communicate with itself via network protocol .
Dns.GetHostEntry(IPAddress.Loopback).HostName returns the host name of your machine. When you pass a host name to TcpClient , it will resolve it to one or more IP addresses using Dns.GetHostAddresses(hostName) . This includes the public and local IP addresses of your machine (e.g. 192.168.12.10), but not 127.0.0.1 (loopback address). So your client is trying to connect to any of the non-loopback addresses of your machine, while your server is listening only on the loopback address . So, no connection can be established. The solution to this problem is that connect to the same end point your server is listening on.
