Regarding Last value of StoryID in News
Dear all,
belows are from equivalent news story but shows different last value like :1, :10, :11 and :12.
Could you kindly guide me relationship between last value of StoryID and VersionCreated?
StoryID VersionCreated
urn:newsml:reuters.com:20190604:nW8N21Z05Y:1 2019-06-04 13:56:59.000
urn:newsml:reuters.com:20190604:nW8N21Z05Y:10 2019-06-04 13:52:37.000
urn:newsml:reuters.com:20190604:nW8N21Z05Y:11 2019-06-04 13:52:37.000
urn:newsml:reuters.com:20190604:nW8N21Z05Y:12 2019-06-04 13:52:37.000
Thanks in advance.
Regards,
Hailey.
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonnews
I have verified the raw JSON headlines by setting the value of raw_output to True.
headlines = ek.get_news_headlines("R:EXEP.PA", count=100, raw_output=True)
I found that those headlines before 13:56:59 are alerts.
When a newsworthy event occurs, the first part of a story may be an alert, a short sentence in upper-case that contains the facts and essential detail. Often several alerts are filed in quick succession. For more information about alerts, please refer to MRN DATA MODELS AND ELEKTRON IMPLEMENTATION GUIDE.
jirapongse, Thank you so much!!
@Hye Young.Cho
From my finding, it is a RevisionId.
  RevisionId is a positive integer indicating which revision of a
         given NewsItem this is.  Any positive integer may be used, but
         it must always be the case that of two instances of a NewsItem
         that have the same ProviderId, DateId and NewsItemId, the one
         whose RevisionId has the larger value must be the more recent
         revision.  A RevisionId of 0 is not permitted.
The format of NewsML URNs is defined in RFC 3085.
Hi jirapongse, Thanks for your comment!
However in this case, the time shows 13:56:59 for RevisionId:1 and
13:52:37 for RevisionId:12. Do you know the reason why? thanks in advance!
Regards,
Hailey
