How to create a case screenning by Word-Check API?
Hello.
I'm brasilian and I got a manual of Word-Ckeck API from Thomson Reuters.
I'm trying to call the API to create a case, but I'm facing difficulties.
When I call the API, the error "Could not get any response" is returned.
Where am I going wrong?
Best regasds.
  "caseId":"TestDemoCase001",
  "groupId":"{
  {group-id}}",
  "entityType":"INDIVIDUAL",
  "providerTypes":[ "WATCHLIST" ],
  "name":"Riduan Isamuddin",
  "secondaryFields":[
      "typeId":"SFCT_1",
      "value":"MALE"
world-checkworld-check-onescreening
4.5k 4 7 8
@Hudson Ventura,
Thank you for your query.
From the screenshot, it seems that the endpoint which you are hitting is incorrect. The correct endpoint for saving the case is - 'https://rms-world-check-one-api-pilot.thomsonreuters.com/v1/cases'
Can you please correct the endpoint and then try again?
Also, are you using any proxy settings using postman?
