Cash flow bond structure using Datascope Select API
cashflowcalc.jpgDear all,
I have a client asking about how to retrieve the Cash flow bond structure using the DSS API.
Using a calculator (for Eikon) we can retrieve all of periods for bonds, for example: PEP21400M106, but I’m unable to retrieve all of periods using the DSS GUI. (the amount of periods changes, depending of the bond, and trough the GUI I unable to specify the necessary fields for this data). Anyone knows if is possible implement it using the Datascope API?
dss-rest-apidatascope-selectdssbonds
13.7k 26 8 12
@caio.zentil, this forum is aimed at software developers using Refinitiv APIs. The moderators on this forum do not have the required deep expertise in all the content sets available through our products to answer your question. I advise you to contact the Refinitiv Helpdesk in your country. They will either have the answer for you right away, or will reach out to the content experts who can provide the answer you're looking for.
