Category in SEQ-case-investigate-results: Get screening results
Hello team.
On SEQ-screen-sync-individual: Perform Synchronous Screening: Individual
response have
categories[
Set of [ProviderSourceTypeCategory] (#ProviderSourceTypeCategoryDetail) names of this Result's sources.
categorystring($string)
maxLength: 255
The category of the Result, i.e. POLITICAL - INDIVIDUAL, INDIVIDUAL, DIPLOMAT, TERRORISM, CRIME - NARCOTICS,
CRIME - ORGANIZED, CRIME - OTHER, CRIME - NARCOTICS, CRIME - FINANCIAL etc.
On SEQ-case-investigate-results: Get screening results
response have only categories
How can I determine that someone got category?
Eg. On Pilot envirovment CaseId: 2252c9dc-fd2e-49be-af4e-1e0b7adbcd38
CaseSystemId: 0a3687cf-68f0-1b73-9a43-778d00000287
"resultId": "0a3687cf-6a9d-143f-9ab6-996b00174639"
"categories": [ "Other Bodies" ],
"category": "CRIME - FINANCIAL"
world-checkworld-check-one
2.4k 5 5 5
@mikhail.romashov
Categories in the sync screening and get screening results response give you a broad list like Law Enforcement, other bodies, PEP, regulatory enforcement, etc.
Whereas Category gives you a precise list like POLITICAL - INDIVIDUAL, INDIVIDUAL, DIPLOMAT, TERRORISM, CRIME - NARCOTICS, CRIME - ORGANIZED, CRIME - OTHER, CRIME - NARCOTICS, CRIME - FINANCIAL etc.
So the categories that you see in sync screening response and get screening results response is the same, it displays the same information, in sync screening we provide the additional field category to your customers for more precise info on the category they belong to.
We are working on making the response of both the API calls same, but I do not have a timeline on when it will be implemented.
2.4k 5 5 5
@mikhail.romashov
Thanks for the query , let me look into this further and get back to you shortly.
Hello, Mehran.Ahmed Khan.
Thanks for your answers.
According to world-check-one-category-definition-04-jan-2019
Field Update Category CATEGORY C2
How I can get update for CATEGORY field It?
2.4k 5 5 5
@mikhail.romashov
Let me look into this further and get back with my response
https://community.developers.refinitiv.com/questions/39670/working-with-ogs-cases.html?childToView=44331#comment-44331
According to answer of your colleague should call 'SEQ-case-investigate-world-check-profile: Get a World-Check profile' for each profile from the results. It's sad because we don't know what fields are changed. We know only that result are modified in general.
2.4k 5 5 5
@mikhail.romashov
Every profile update is categorized into one of four Category Update buckets (C1, C2, C3 or C4).
C1 updates are typically the most important (i.e. we update the name fields, aliases or other critical details) whereas C4 is the least critical (i.e. we add an additional hyperlink to the profile, etc). The attached document explains what type of update corresponds to which category.
If you have Advanced (Premium Plus) access, theupdate-categorization-aug-2018.pdfre is a feature on the UI ADMIN Settings section call Category Update Notifications (see attached image) where you can choose to suppress certain types of updates. So for example, you might not want to get any C4 updates in Ongoing Screening, you can you chose to only have alerts for C1-C3 (or C1-C2) and so forth.
If you just have Standard access, you get alerted to all profile updates but if you have Advanced, you can choose which categories of updates you want via the OGS (Ongoing Screening) process!
