Exact ORG ID or RCP ID match based on Company Name
Hi All,
We need to find the exact name search for companies, client has a list of DUNS(which is no longer supported in DSS) apart from that client has only Company Name, City, State,and address only.
Below is what we tried but we get 4 outputs.
{ "SearchRequest": {
"Name":"Deutsche Bank AG",
"OfficialNameOnly": true,
"DomicileCodes": [],
"CountryOfIncorporationCodes": ["DE"],
"TrBusinessClassificationCodes": null,
"VerifiedOnly": false,
"RegulatedOnly": false,
"IssuersOnly": false,
"ActiveOnly": true,
"IdentifierType": "RcpId",
"PreferredIdentifierType": "RcpId"
Thanks in advance.
Regards,
Prathibha M
dss-rest-apidatascope-selectdssentity
13.7k 26 8 12
@Prathibha.Mariyappa,
I'm not 100% sure of what you are trying to achieve with this Entity Search call, but to narrow down the results to only 1 item I'd suggest you change the following parameters:
"DomicileCodes": ["DE"],
"IssuersOnly": true,
"VerifiedOnly": true,
The first one of these 3 you might want to reconsider, depending on the use case, but the other two are usual settings I believe. Here is the resulting call:
Method: POST
Endpoint: https://hosted.datascopeapi.reuters.com/RestApi/v1/Search/EntitySearch
Body:
    "SearchRequest": {
        "ActiveOnly": true,
        "Name": "Deutsche Bank AG",
        "RegulatedOnly": null,
        "Identifier": null,
Result:
  "@odata.context": "https://hosted.datascopeapi.reuters.com/RestApi/v1/$metadata#Collection(ThomsonReuters.Dss.Api.Content.ValidatedEntity)",
  "value": [
      "@odata.type": "#ThomsonReuters.Dss.Api.Search.EntitySearchResult",
      "Identifier": "10459",
      "IdentifierType": "OrgId",
      "Key": "VjF8MHgwMDAzZWYwNmMzYWEwNjg1fEVORU58MTA0NTl8T1JH",
      "Description": "DZ BANK AG Deutsche Zentral-Genossenschaftsbank, Frankfurt am Main",
      "InstrumentType": "Entity",
      "Type": "Business Organization",
      "Domicile": "Germany",
      "CountryOfIncorporation": "Germany",
      "ParentOrgId": "10459",
      "UltimateParentOrgId": "10459"
Hope this helps.
