Re-screeening uses different sources
We create cases and get the results by calling /cases/screeningRequest. The case is created using a group id that only has categories 'Sanctions' and 'Other Bodies'.
The problem is when we re-screeen the case using /cases/{caseSystemId}/screeningRequest it appears that all categorizes are selected. Because then we re-screen the case we get matches i RE, PEP and so on.
Is this a bug or are we doing something wrong?
world-checkworld-check-onescreeningscreening-api
This was caused by the fact that Ongoing screening had different sources. When a case is added to ongoing screening it is screened again against the new sources.
4.5k 4 7 8
@eirik.yksnoy,
Thank you for your query.
I will look into it and get back to you shortly.
4.5k 4 7 8
@eirik.yksnoy,
If you are using the same group for screening / re-screening, then you should get the expected result. If you are using a different group, which has different settings then the result would vary.
If you have created a case using a group which has all the sources, then it will retain the results even if you have updated the group while rescreening.
I have forwarded you query to support team for further assistance. They will get back to you with their findings.
