Time Series Data API is not working for the RIC Code INRDECM=
We are using Time Series Data API to fetch the forward rates using RIC Code, But we are not able to get the data for December month using the RIC Code (INRDECM=)
But through excel we are able to get the data for above RIC code. Whether we need to give a different RIC code while fetching the data from API?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythontime-series
3.8k 4 4 6
Hi @Maharajan
I suggest you to try with the TR.xxx fields and get_data method. You will receive a complete timeseries for that request.
ek.get_data("INRDECM=", ["TR.BIDPRICE.date","TR.BIDPRICE"],{'SDate': '2016-01-01', 'EDate': '2019-01-31', })
Hi @marcin.bunkowsk we are getting the attached error-response-from-thomson-reuters.png error while getting the response using ek.get_data method. Whether we have done anything wrong?
@Maharajan
What is the exact set of parameters you used in your get_data call? Are you able to retrieve data into Excel using =TR worksheet function and the same set of parameters you used in get_data method? Using the example @marcin.bunkowski provided the equivalent =TR worksheet function is
=TR("INRDECM=","TR.BIDPRICE.date;TR.BIDPRICE","SDate=2016-01-01 EDate=2019-01-31")
Hi @Alex Putkov.,
We are getting the same Access Denied error while trying to retrieve the data from below Excel function
=TR("INRDECM=","TR.BIDPRICE.date;TR.BIDPRICE","SDate=2019-06-13 EDate=2019-06-13")
Then the issue you experience is not specific to utilizing Eikon Data APIs and is best dealt with using regular support channels rather than on this forum. I suggest you open a case with Refinitiv Helpdesk. The Helpdesk can verify data entitlements for your Eikon user account and can troubleshoot the issue, which is not something that can be effectively done on a forum.
