WC1 API Run Result 109 pass, 64 failed
Hello team.
I started to lean WC1 API and run the collection in Postman according to Quick Start guide.
The result is awful: 109 pass, 64 failed.
seq-case-investigate-results-get-screening-results.zip
Explain me please, why?
Eg: POST cases/screeningRequest
SEQ-screen-sync-simple: Perform Synchronous Screening: Simple - Result is 200 OK
SEQ-screen-sync-individual: Perform Synchronous Screening: Individual - Result is 500 Internal Server Error
world-checkworld-check-one
4.5k 4 7 8
@mikhail.romashov,
Thank you for sharing the file.
Can you please also provide us the request body which you are sending for the saving / screeing a case for which the response code is Error 500?
Also, I see that the timestamp of all the Error 500 is -
"time": "2019-04-26T10:12:33.479Z",
Can you please confirm if all the API calls were sent during the same time? As I also do not see the timestamp of few API calls.
I hope I've solve a problem it's empty customFields. If i remove it that result is 200 ok.
But i expected 400 Bad Request error, not 500 Server errror.
"timestamp": "2019-04-26T10:12:33.479Z" and "delay": 2000 acording to Quick Start guide.
seq-screen-sync-individual-perform-synchronous-scr.txt
4.5k 4 7 8
@mikhail.romashov,
Thank you for your query.
Unfortunately we are unable to access the .zip file shared above. Can you please share the result in text file?
Please check your access to attach
thomson-reuters-world-check-one-api-v15postman-tes.txt
