EDD API - report type and sub report type ID
As I cannot find the mapping between the code and value of report type/sub report type, we do not know what values we should pass into the API, can you help?
world-checkscreeningscreening-apielektron-data-dictionary
Hi @andrew.lee,
Could you try to use the GetMaster request, and then find the <ClientResult> section with the necessary ClientCode, this response block contains <ReportObjects>, which includes all types of reports and subreports that you can use.
For example, in the attached screenshot you can see report-subreport mapping for ISRPT2:
Hi team, will it be any update for this? Thanks.
Hi team, any update
Hi team, great, so if I would create report type and sub report type similar to our production environment, how to do it? Thanks.
Could you please explain what you mean? Do you want to add report/subreport to EDD UAT?
Yes, exactly.
@Vladyslav.Kysil, the last customer query is still open (how to add report type and sub report type in UAT, similar to prod environment). Can you please answer it ? Thank you.
