can anyone please explain the following ADH-2.6.2 errors and warnings (see details below)?
<trep-adh-1.1.adh.rrcpTransport.1.srcSide.rrcp.send.transmissionBus: Warning: Thu Apr 25 22:53:11 2019> RRCP STATUS MSG: RRCP_RESYNC: resync'd with node 33001 <END> <trep-adh-1.1.adh.rrcpTransport.1.srcSide.rrcp.send.transmissionBus: Warning: Thu Apr 25 22:53:11 2019> RRCP STATUS MSG: RRCP_BC_MISSEDMSGS: gap in broadcast msgs from node 33001 <END> <trep-adh-1.1.adh.sourceApplicationPool.sslIpcSessionHandler.source.server.ipc.transmissionBus: Error: Thu Apr 25 22:53:23 2019> sipcSBind failed for rmds_ssl_source. <<ipc/sipcsrvr.c:1062> sipcBindSocket() failed (98)>. Will try again in 30 seconds. <END> <trep-adh-1.1.adh.rrcpTransport.1.srcSide.rrcp.send.transmissionBus: Warning: Thu Apr 25 22:53:24 2019> RRCP STATUS MSG: RRCP_REBOOT: node 33001 has rebooted <END>
elektronrefinitiv-realtimetrepinfrastructure
@Kam.Anjorin
You can find information regarding these errors and warnings in the ADH installation guide.
For the RRCP_RESYNC, RRCP_BC_MISSEDMSGS, and RRCP_REBOOT status messages, please refer to section 17.7 RRCP Error Messages in the ADH installation guide.
For the below error, the ADH was unable to bind on the rmds_ssl_source TCP port with the EADDRINUSE (98) error.
This port may be used by another application.
For more information regarding these errors, please directly contact TREP support team via Get Support at my.refinitiv.com.
