I do receive the following message error after typing 'pip install eikon' in the command line:
Collecting eikon
Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)
after connection broken by 'NewConnectionError('<urllib3.connection.VerifiedHT
PSConnection object at 0x00000000056D2630>: Failed to establish a new connectio
: [Errno 11004] getaddrinfo failed',)': /simple/eikon/
Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)
PSConnection object at 0x00000000056D25C0>: Failed to establish a new connectio
Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)
PSConnection object at 0x00000000056D2518>: Failed to establish a new connectio
Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)
PSConnection object at 0x00000000056D2710>: Failed to establish a new connectio
Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)
PSConnection object at 0x00000000056D2208>: Failed to establish a new connectio
Could not find a version that satisfies the requirement eikon (from versions:
No matching distribution found for eikon
